Hardware choice for off-line personal use?
Hello LM Team,
Kindly asking for any recomendations for a decent mini desktop computer box or something along those lines. For future proofing my personal files. I would also like to be able to run something other than windows. Thanks!
I recommend watching the yt channels ‘hardware haven’ ‘craft computing’ and ‘Jeff geerling’ which are all about the homelab, each with a different focus.
The NovaCustom PrivacyGuard NUC Box (with coreboot) mini PC comes with Zorin OS (Linux) that looks like an easy transition from Windows or macOS
For future proofing your personal files, the storage setup matters more than the box itself, so plan for a second drive and an external backup rather than relying on one disk. On the OS side, most mini PCs in the NUC form factor run Linux without trouble, and distros like Zorin or Mint do ease the move from Windows. If the coreboot firmware angle matters to you, that NovaCustom option is worth a look, though compare the specs and price against mainstream mini PCs before deciding. What size of files are you planning to keep?
Yes, ideally, you’ll want to keep 3 separate copies of your files that are in different factors. In addition, you’ll want to encrypt your files for privacy - if that matters to you.
The 3-2-1 point is the one I’d build the setup around. For an offline personal box, a second internal drive plus an external copy and one kept somewhere separate covers most loss scenarios, and full-disk encryption is easy enough to enable at install time with most Linux distros. On the NUC question, I’d weigh how much the coreboot firmware matters to you against the price gap versus mainstream mini PCs, since specs on paper often look similar. File sizes probably decide the drive layout more than the distro does, so what are you storing?
If you want to go budget, you can get a used Lenovo M710. M720, M910, M920 on ebay for under $200… You won’t have a lot of processor cores like the new PC’s, but you can find a 920 with 8 cores, 16 GB RAM, and put a Linux distro like the aforementioned and have a great PC as long as you’re not doing processor heavy tasks like video editing.
The point about file sizes deciding the drive layout is worth emphasizing. In Minneapolis, I’d also factor in power reliability and physical security when deciding where that separate copy lives. For the budget used Lenovo route, checking whether the unit supports full-disk encryption cleanly in the BIOS is worth doing before buying, since some business machines have quirks there. The coreboot tradeoff on the NUC comes down to whether firmware transparency is a real priority for you or just a nice-to-have compared with the price difference.
