Plan 9 / 9 Front: Avoiding the megacorp trap
I just watched Loyal’s recent video on the enclosure of the home PC: https://www.youtube.com/watch?v=L1Gn3WChZjI. I agree 100% with the diagnosis, but I have a
different take on the solution.
Instead of Linux—which is increasingly being compromised by corporate steering, 30-million-line kernel bloat, and the same remote-attestation drift—I suggest
looking at Plan 9.
It was created by the exact same Bell Labs pioneers who created UNIX (Ken Thompson, Dennis Ritchie, Rob Pike). They saw the architectural dead-ends of POSIX in the late '80s and designed the cure. It was largely ignored back then because corporate bean-counters didn’t want to risk money on something that was more secure and
radically simpler by default.
Today, 9front is the primary fork kept in active development by independent volunteers.
In my opinion, the real opportunity is to take 9front as the bedrock for true sovereign, privacy-first computing. Because of its design (per-process namespaces,
zero background telemetry, and strictly everything being a 9P file), surveillance and telemetry are architecturally impossible.
I’ve been diving deep down this rabbit hole: writing modern 9P-protocol bridges to connect Plan 9 with contemporary networks, building resilient multi-machine
cluster runtimes, and even developing a new language (Objective-9C) to make writing graphical applications ergonomic without being stuck in raw C.
The lack of a bloated commercial software ecosystem is both a blessing and a curse. But download the 9front ISO and spin it up. It’s not Unix, and it’s not Linux.
It’s small, un-enclosed, and sitting right on the computing frontier.
The source is open, and the opportunity is there if you want to break free from corporate computing once and for all.
The architectural point about per-process namespaces and 9P is worth taking seriously, and it’s fair that a small system has less surface for remote-attestation drift to creep into. Where I’d push back is treating telemetry as impossible by design: everything being a file still means a file someone can read, log, or forward, so isolation depends on how services are configured, not just the model. Also, a fork kept alive by volunteers inherits their time constraints for drivers and hardware support. Worth experimenting with, but I’d frame it as a deliberate trade-off rather than a solved problem.
What about a coreboot PC with intel disabled running Arch Linux (with say i3)? There’s always Linux Tails. You also need to have better routers and firewall rules. :wink:
I also agree with having local LLM’s. I think a BIG overlooked problem is everyone’s smart phone and smart devices sending data back to the corporations. How many of you are running a de-googled pixel with Graphene OS like me? What about your social media accounts (none here)? Let’s not mention your smart TV. VLANS are a must!!! I’m ditching my macbook as soon as my NovaCustom PrivacyGuard NUC Box (with coreboot) mini PC arrives. Going to run Arch Linux on it.
[Coreboot PC Client (Arch/Tails)]
▼ (Forced Transparent Routing via TOR_LAN Interface)
[Hardened Gateway Box (OPNsense Router)]
├──► [Drops Telemetry locally via DNS Sinkhole / DPI]
│ ├─── Unbound DNS: Resolves queries using Mullvad’s Ad/Telemetry Blocklist DNS
│ │ or drops them locally to 0.0.0.0 via local blocklists
│ ├─── Zenarmor (DPI): Continues tracking TLS SNI handshakes to drop hardcoded IP traffic
│ └─── Firewall NAT: Force-redirects ALL traffic from the client network into the
│ Mullvad WireGuard Virtual Interface (wg0)
▼ (Encrypted WireGuard Tunnel: Persistent Connection to Mullvad Relay)
[Starlink Router (Bypass Mode)]
▼ (Blended with thousands of CGNAT users)
[Mullvad RAM-Only VPN Endpoint] ───► [The Real Internet (Clean, High-Speed, No CAPTCHAs)]
